04-16-2024, 09:31 AM | #1 |
A Porsche lover
23
Rep 27
Drives: M3
No engine oil change at break-in?
I just left the car for the break in service, 11xx miles, the service advisor checked and said only diff oil has to be changed, and the instruction is from the BMW system.
Is it normal that engine oil change is not a part of the break in..? (USA) UPDATE: GM came out and apologized as it was a miscommunication from the SA, the engine oil change is included. Last edited by ryanm3; 04-16-2024 at 12:27 PM.. |
04-16-2024, 10:30 AM | #3 |
Rep 3,260
SAs (service advisors) are notorious for not fully understanding what the job is. The paper you get will confirm what work is done and the techs follow guides directly from BMW for each service that's requested. Unless the paper says it's not done then it will be done.
forcefed3043.50 |
04-16-2024, 11:14 AM | #5 |
A Porsche lover
23
Rep 27
Drives: M3
But if they read from the BMW system then it is also not the SA’s fault, should I call BMWNA?
04-16-2024, 11:43 AM | #6 |
Rep 2,198
GolfCoyote985.50 |
04-16-2024, 12:11 PM | #7 | |
Rep 2,307
All brake in service includes engine oil and diff fluid, just wait for your paperwork and forget about the SA.
04-16-2024, 12:27 PM | #8 | |
A Porsche lover
23
Rep 27
Drives: M3
forcefed3043.50 |
04-16-2024, 08:07 PM | #10 |
Rep 167
Same thing happened to me. SA insisted that there is no oil change just the ecu needs to be updated so it can have full power. Her logic was M4s are basically like race cars, so they don't need an oil change. And they need hook up to the ecu to make sure car is running like a race car. I am not making any of this up. I insisted for her to go check with the service manager to make sure. She comes back 10 min later, still not acknowledging her blunder but saying once they hook up the computer they will know if the car needs an oil change or not. Needless to say in an hour I received a video of the car getting drained all the fluids. I wonder how many m cars in my area still running with break in oil. 😔
0-60 3.08 sec (dragy verified)
1/8 7.21 sec (dragy verified) 1/4 11.22 sec (dragy verified) 60-130 9.35 sec (dragy verified) 0-130 12.61 sec (dragy verified) |
04-16-2024, 10:02 PM | #11 |
Rep 1,823
FYI, in case anyone wasn’t aware, SA stands for Stupid Ass.
I’m always amazed why most, if not all, in that field don’t actually take the time to educate themselves for the job they’re doing. |
04-18-2024, 04:41 PM | #13 | |
2067
Rep 2,005
Drives: E92 M3
The people that are actually working on the cars will be knowledgeable.
04-19-2024, 09:51 AM | #14 |
A Porsche lover
23
Rep 27
Drives: M3
04-19-2024, 10:12 AM | #15 |
Rep 1,823
The irony of that is even that logic is WRONG, because guess what?… Race cars usually run race oil and that oil has even less detergent additive packs to it, so it requires even more maintenance and less time during intervals of change. That’s why they tell you NOT to run race oil in your everyday car if you’re doing extended interval changes. 🤦*♂️🙄
RUNSOK414.00 |
04-19-2024, 11:44 AM | #16 |
Rep 179
Drives: AW G80 6MT
My experience with many different brands has varied on the specific SA. Those that are car enthusiasts are great to work with as they share the passion. Went in for an oil change at my local dealer today for the first time and my SA specifically said "obviously we will not run your car through our automated wash"
We even had a good chat about our passion for cars and history of past cars / mods that we have done. |
04-23-2024, 06:31 PM | #17 |
Rep 337
Took mine in for break-in service today (@ 1,203 miles). The print out is quite interesting:
1. The engine oil (0W30 full synthetic) has the quantity '70' listed. So clearly not quarts or liters, but fractional quarts or liters...like a deciliter?? 2. I assume the rear differential is the 'hypoid axle oil' with the quantity '2' listed. 3. My favorite line in the work order: "Customer States Invisible Service Performed (Yes) (No)". I'll upload a pic later. 4. "CBS Data shows car due for standard scope. Service due. Perform standard scope service." Also, I found it odd that when I checked on the car's location in the app, it was in a residential area--that is not cool. There were 5 miles tacked on to the odo--I can understand a mile or two, but come on guys. Last edited by Pool Shark; 04-23-2024 at 06:36 PM.. Reason: Added service work order pic |
04-23-2024, 07:49 PM | #18 | |
Rep 2,198
Pool Shark789.00 |
04-23-2024, 07:54 PM | #19 | |
2067
Rep 2,005
Drives: E92 M3
Some of them prefer a test drive to make sure the diff oil is performing as expected (previous generations had some noise issues) to save you a return trip in case of an issue and others don't care as much. 5 miles is reasonable for a test drive, a mile or two won't warm up much. If this is a concern for you, next time request that they contact you prior to any test or diagnostic drives.
Pool Shark789.00 |
04-23-2024, 08:43 PM | #20 | ||
Rep 337
kgelfen3602495.50 |
