10-06-2023, 10:04 AM | #1 |
Rep 191,503
**the new** mishimoto 2021+ bmw g8x m3/m4 3.0l s58b30 open airbox performance intake
BEST DEAL!!
The BMW G8X M3 and M4 are automotive engineering masterpieces and Mishimoto is committed to highlighting every ounce of their potential, including their auditory prowess. This Mishimoto open airbox performance intake is designed to unleash the sound of power from the S58 under the hood of your 2021+ BMW G8X M3/M4. The open-element design of this intake is fine-tuned to allow your turbos to breathe freely and deliver an enhanced and aggressive engine note. Get ready to roll down the windows, punch the throttle, turn heads, and ignite your passion for driving. With this intake installed, you'll get to revel in the sound of turbo spool and BMW's legendary induction sound with every RPM. The Mishimoto 2021+ BMW G8X M3/M4 open airbox performance intake is engineered as a complete bolt-on kit and includes everything you need, making installation a breeze. The durable steel heat shields are powder coated in a sleek micro-wrinkle black finish to withstand the harshest environments while adding to the aggressive styling of the G8X engine bay. Two high-quality washable oiled filters protect your S58's sensitive internals from dust and debris, while the rotational-molded intake tubes isolate the intake air from engine bay heat. Like all Mishimoto BMW products, this intake is backed by the Mishimoto Lifetime Warranty for as long as you own the vehicle. If you're ready to unleash the true sound of your 2021+ BMW G8X M3/M4 and experience the thrill of auditory performance, then it's time to upgrade your driving experience with Mishimoto's open airbox performance intake. PRODUCT FEATURES Direct fit for 2021+ BMW G8X M3/M4 with 3.0L S58B30 Greatly enhances turbo spool and induction sounds Open filter elements and black powder coated heatshields for a sleek and aggressive look Installs in less than 1 hour with no need to remove the front bumper or undertray Steel heatshields deflect heat while allowing maximum flow and sound Rotational molded tubes isolate intake air from engine bay heat CNC-machined aluminum connectors for maximum durability and a leak-free install Passenger-side turbo inlet improves flow and durability Washable oiled filters can be cleaned and refreshed using available filter re-oil kit Patent Number 11,506,157 B2 Mishimoto Lifetime Warranty PURCHASE INCLUDES (1) Driver-Side Intake Heatshield Assembly (1) Driver-Side Air Filter (1) Driver-Side Intake Tube Grommet (1) Driver-Side Intake Tube Coupler (1) Driver-Side CNC Quick-Disconnect Fitting (1) Passenger-Side Intake Heatshield Assembly (1) Passenger-Side Air Filter (1) Passenger-Side Intake Tube Grommet (1) Passenger-Side Intake Tube Coupler (1) Passenger-Side Aluminum Turbocharger Outlet (5) CNC-Machined Airbox Peg Kits (4) Stainless Steel Worm Gear Clamps Mounting Hardware
10-30-2023, 06:56 AM | #2 |
Rep 191,503
11-16-2023, 06:42 AM | #3 |
Rep 191,503
12-18-2023, 06:45 AM | #4 |
Rep 191,503
01-08-2024, 08:33 AM | #5 |
Rep 191,503
01-25-2024, 07:36 AM | #6 |
Rep 191,503
02-13-2024, 06:52 AM | #7 |
Rep 191,503
03-01-2024, 06:49 AM | #8 |
Rep 191,503
03-21-2024, 06:36 AM | #9 |
Rep 191,503
04-22-2024, 10:47 AM | #10 |
Rep 191,503
bump
05-17-2024, 12:47 PM | #11 |
Rep 191,503
bump
