08-30-2022, 09:35 AM | #178 | |
Rep 2,142
Did you have to code the European blinker to have the inner DRLs stay on when blinkers are on? |
hawaiiracer1275.00 |
08-30-2022, 09:40 AM | #179 | |
Rep 2,142
Really hoping to get mine by next week! |
08-30-2022, 12:15 PM | #180 |
Rep 2,142
08-30-2022, 09:25 PM | #181 | |
Rep 166
heres a forum for that |
Limegrntaln13707.00 mydxb59.00 |
08-31-2022, 08:00 AM | #182 | |
Rep 2,142
I was wondering if hawaiiracer1 coded his, or if it was the LED board setting. Apparently, it's the latter. |
j0e612130.00 hawaiiracer1275.00 |
08-31-2022, 08:04 PM | #183 |
Rep 1,683
Just my luck as I was going to get the LED replacement my headlight messes up. Filled with condensation for 3 days now. Taking it to the dealership tomorrow.
On a positive note I did get the thermal glue. |
09-01-2022, 08:07 AM | #184 | |
Rep 104
Is it possible I can set the color and then disconnect all the wires? |
09-01-2022, 10:48 AM | #185 | |
Rep 104
Can I set the color once then remove all the cables? I don't see myself changing colors that much once set. |
09-01-2022, 02:13 PM | #186 |
Rep 104
Just watched your video again. On the top heat sink where we tucked the original board out of the way while connected, it was originally connected to a heat sink. Will that board burn out overtime with no heatsink?
I'm guessing if we disconnect it it'll throw an error. |
nearwater4me1924.50 hawaiiracer1275.00 |
09-01-2022, 02:41 PM | #187 | ||
Rep 2,142
I'm worried about the long term reliability of these LED boards AND the stock one that's tucked away. |
09-01-2022, 03:37 PM | #188 | |
Rep 1,683
Mraceguy113.50 |
09-01-2022, 04:20 PM | #189 | |
Rep 2,142
Please understand my concern, because the installation is not what I initially expected - with wires pinched between the housing and heatsink, and with the OEM board tucked away. I was under the impression that this was just a simply LED board swap. These changes introduce risks that were not taken into account when the light assembly was engineered. Your months of use isn't enough to fully simulate real lifetime usage. That said, I'm sure the main LED low beams generate MUCH more heat than the DRLs, so I could be overreacting. Just saying we can't know for sure what kind of long-term reliability issues we might run into without seeing real test data. I guess time will tell. Are you saying you're offering a 3-year warranty on these LED kits? |
09-01-2022, 04:40 PM | #190 | |
Rep 1,683
09-01-2022, 08:49 PM | #191 |
Rep 8,113
Drives: 2024 X5 M60i
After rewatching that video, I have to agree that I'm not sure about the whole "tucking away the OEM boards". They are attached to a heat sink for a reason and now we are instead just keeping them attached and tucking them away while also stuffing another one in there?
09-02-2022, 12:14 AM | #193 |
Rep 346
Limegrntaln13707.00 hawaiiracer1275.00 |
09-02-2022, 12:21 AM | #194 | |
Rep 346
Suggest to have additional heatsinks for them while tucked away in there. Or better yet need a dummy / simulator board to plug in to bypass error. |
09-03-2022, 02:53 PM | #195 |
Rep 64
Install RGB kit , was pretty easy
09-03-2022, 08:44 PM | #196 |
Rep 8,113
Which epoxy or thermal paste did you end up using?
How long did it take you to do the install?
09-03-2022, 08:57 PM | #197 | |
Rep 64
Take 5-6 min to dry and take about 2 hour to install everything! Last edited by Pirate1; 09-04-2022 at 12:15 PM.. |
09-03-2022, 09:23 PM | #198 | |
Rep 8,113
I don't even have a jack, jack stands, or a torque wrench. My initial plan was to get a floor jack and a torque wrench for this install but didn't think about needing jack stands as well in order to be able to do both sides so that I'm not waiting an entire day for the drying time alone. 🤦🏻
Limegrntaln13707.00 |
