07-25-2022, 10:04 PM | #67 | |
BMWnation
425
Rep 514
Limegrntaln13705.50 |
07-25-2022, 10:53 PM | #68 |
Rep 7,033
Im killing myself. I wasted a whole week trying to figure out who could even install these. Did I need to go to the dealer to get them installed, because there was a software update? No, that's not the case. I can technically get them installed, anywhere.
It would be physically easier, and more trusting for me to drive my car down to LA to get these installed, but, I thought I would be able to sneak out the back door, and do a turn and burn, but that proved harder than I anticipated. The truth is, I'm going to probably end up getting them installed, locally, because the logistics of driving a 900 mile round trip, is going to be too much of a pain in the ass for me, including a mini vacation etc, and possibly having to bring 2 cars. I'm already going to Hawaii, in 3 weeks, for 7 days, I should just be able to take my car where I want, without a hassle, but, it just ended up in a little argument.
YT: G Dubyou |
07-25-2022, 11:00 PM | #69 | |
Rep 846
Drives: 2009 E93 M3
Garage List 2008 E90 M3 [0.00]
1995 BMW M3 [0.00] 2004 BMW M3 [0.00] 2011 BMW 335xi [0.00] 2011 BMW 335is [0.00] 2009 BMW M3 [0.00] |
Limegrntaln13705.50 r33_RGSport13118.00 |
07-25-2022, 11:18 PM | #70 |
Rep 7,033
I believe the dealership has their standard procedures to connecting to the vehicle when you bring it in. If it was an ongoing issue, the hundreds of KW installs would all be problem, especially for the people that just install in their driveway.
YT: G Dubyou |
07-25-2022, 11:21 PM | #71 |
Rep 168
Im surprised a press is needed for this. Spring/strut compressor yes, but a Hydraulic press? Ive done a few sets of adjustable height spring installations, never needed a press.
07-25-2022, 11:26 PM | #72 |
Rep 7,033
There are always different ways to do things. I've seen people hold it with one hand and hit it with a hammer, with the other hand. Same people that use a combination wrench to hammer on the back of a screwdriver.
YT: G Dubyou |
07-26-2022, 10:02 AM | #73 | ||
Rep 18,792
Is it necessary? Yes and no, depending on where you live. For my local customers, they live in the city, so everywhere is pretty well lit. I adjusted my G05 X5 because I took it for road trip and when in the middle of nowhere, you can't see as far. But, before I did adjustment, I just use my other build-in feature in the car. The High Beam. Quote:
Yes, some guys uses mallet, which is fine to knock it off. But to install the KW spring perch, if you didn't hit it evenly, you can damage the aluminum shock body and may not be pressed properly. Seen that happened to one local customer F90 M5 with Dinan HAS that he purchased used. Not sure how it was installed, but the aluminum shock body all messed up which causes noise and uneven height on all 4 corners.
07-26-2022, 10:20 AM | #74 |
Rep 214
This press worked great for my KW HAS install and then you can return it.
https://www.harborfreight.com/12-ton...8aAt5XEALw_wcB |
Limegrntaln13705.50 OwnerF16881.50 |
07-26-2022, 11:36 AM | #75 | |
Rep 10,248
To actually adjust the lights- its super easy and all you need is a phillips and turn the adjuster counterclockwise and watch the beam move up to where the oem mark is. I never adjust the horizontal settings.
Limegrntaln13705.50 Team Tonka146.50 r33_RGSport13118.00 BMWRacer5232522.00 'Cane8723.50 BMWGirlFL6375.00 m.dreamin1614.50 OwnerF16881.50 |
07-26-2022, 11:03 PM | #76 | ||
Rep 168
0 492 417, plate from tool kit, part number 0 492 415 0 493 644, sleeve from tool kit, part number 0 491 939 0 495 343, half-shell from tool kit, part number 0 495 339 5 A36 B04, spring plate, top 5 A36 B05, spring plate, bottom 0 494 933, spring tensioner 2 405 829, installation tool 5 A4A 186, adapter (for cars with all-wheel drive only) Doesnt look like the kit comes with most of these. |
07-27-2022, 02:42 AM | #77 | |
Rep 7,033
The dealer is going to want to install the kit by the book, versus how a set of KWs are installed, simply by measuring the shock body for the spring perch. The M Performance suspension comes with a spring perch tool, and together with the 186 tool, that you would order, it would alleviate having to take shock measurements, as the spring perch tool provided would act like a template, to get the measurement exact everytime. So, if you're going to get the springs installed at the dealer, I would order the 186 tool with the springs. I didn't do this and now it would take a week or better to get the correct tool to work with the spring perch template tool.
YT: G Dubyou |
07-27-2022, 12:16 PM | #78 | ||
Rep 13,023
07-28-2022, 03:16 PM | #79 |
Rep 4,000
FYI, I asked my CA about adding this to my build.
They reached out to BMW NA and it's currently an EU-only option.
Current: 95B.1 Macan Turbo // Dark Blue Metallic - for sale |
Limegrntaln13705.50 T0RM3NT3802.50 |
07-28-2022, 07:16 PM | #80 |
Rep 7,033
Yes, I talked to my local parts counter, and its "blocked" from ordering, according to the dealership. I ordered mine from Germany.
YT: G Dubyou |
07-30-2022, 09:42 AM | #81 |
Rep 788
@Limegrntaln have you seen the m performance coil over kit? I just saw that one I wonder if that's worth the additional $1k (I'm assuming)?
07-30-2022, 01:38 PM | #82 |
Rep 7,033
They have the V3 and the V4 kit out, as far as I know. I was waiting on the actual DDC kit. The V3 and V4 you have to disable the factory suspension electronic dampers. The KW DDC, has a plug to plug the KW shocks into the OEM wiring on the car, so you can change the KW shock settings with your drive modes. The DDC aren't out, yet, as far as I know. I'll post a pic of them, below. And the OEM dampening is so good, it begs the question, is it really needed?
YT: G Dubyou |
Nkr151124.50 |
07-30-2022, 02:39 PM | #83 | |
Rep 788
07-30-2022, 02:44 PM | #84 |
Rep 7,033
This is the kit that this thread is about. The ones I bought from Germany. They're not available for sale in the US, yet.
YT: G Dubyou |
Nkr151124.50 |
07-30-2022, 02:56 PM | #85 |
Rep 788
Got it, I just cant decide if I want to get the HAS or just go straight for the coil over kit if it also has to be shipped over from Germany thats all.
07-30-2022, 03:04 PM | #86 | |
Rep 7,033
Check this thread. https://g80.bimmerpost.com/forums/sh....php?t=1916684
YT: G Dubyou |
Nkr151124.50 |
07-30-2022, 03:19 PM | #88 | |
Rep 788
Tags |
g80 lowering springs, m performance accessories, m performance has, m performance suspension |
