03-06-2023, 09:39 PM | #67 | |
Rep 2,175
03-07-2023, 04:04 AM | #68 |
Rep 126
The spring binds as you turn the wheel. Instead of the spring turning freely as you turn your wheels the spring gets caught for a second then 'springs' round suddenly as the tension forces it to. Creates a knocking sound as you turn at slow speeds (or stationary once it's bad enough) as it gets worse and it binds for longer the intermittent knocking / clunking turns into more of a loud springy ping sound.
That's the best (maybe worst) explanation I've got so hopefully that helps |
KevinGS3389.00 M Division1202.00 |
03-10-2023, 08:35 AM | #69 | |
Rep 34
I did the front first to see if that would look ok by itself, but the rear was way too high in comparison. So I followed it up immediately doing the rears as well. It is pretty much exactly what I was looking for. The rear could be another 3 mm lower to exactly match the front. It rides amazingly well, just a touch firmer than stock, feels quite planted and still quite a nice range of suspension travel. It is quite mild compared to some of the other kits, but it was exactly what I was looking for. It also happens to match the ideal track handling height as prescribed by the M performance HAS. One last thought, I'm not sure how the stock height varies between G80/G82 and x-drive vs non, but doing front-only on a G82 x-drive looked really raked, in not a good way. I'm glad I had both fronts and rears just in case, because the rears are definitely necessary. I can post some images later.
03-10-2023, 08:39 AM | #70 | |
Rep 2,175
I have RWD, but my hunch is the "front only" springs may be too much rake for the RWD as well. But I'll give it a shot, as I'll them install the fronts first. I look forward to seeing your pix. |
03-10-2023, 08:54 AM | #71 | |
Rep 34
1st pic - stock ride height 2nd pic - front only in the shop (sorry I wasn't able to get a better angle) 3rd and 4th pics - eibach pro front and rear drop (current setup)
03-10-2023, 10:35 AM | #72 |
Rep 2,175
3rd and 4th pic is all I need. That drop looks perfect to me, that's exactly what I want. Very subtle, with the forward rake. If the stock ride quality is all but maintained, even better.
In the front-only pic, yes, I can't tell that the rake is too much. But no worries. I'll just install them at all 4 corners. Many thanks! |
ericj0n45.50 |
03-10-2023, 10:37 AM | #73 | |
Rep 34
KevinGS3389.00 |
03-13-2023, 07:39 PM | #75 |
Rep 1,163
Just FYI, the G82/83 have more wheel gap in the back stock than the G80. The G80 kit is front only. Eibach does not prescribe rear springs for the G80.
03-14-2023, 11:04 AM | #77 |
Rep 191,486
fanofbmwe462104.00 |
03-14-2023, 09:04 PM | #79 |
Rep 1,083
Eibach Springs for G80 is front only and is compatible with xDrive
fanofbmwe462104.00 T0RM3NT3802.50 |
03-15-2023, 09:14 AM | #80 | |
Rep 1,030
https://autoid.co/products/eibach-pr...42946429550821 |
03-16-2023, 07:58 PM | #81 | ||
Rep 34
03-16-2023, 08:03 PM | #82 | |
Rep 1,163
ericj0n45.50 |
03-19-2023, 08:18 AM | #83 |
Rep 126
Still need to bed in properly, but eibachs on all round on the xdrive.
03-29-2023, 04:43 AM | #85 |
Rep 126
05-26-2023, 07:05 PM | #88 |
Rep 239
Went hunting for the front only 20mm / E10-20-049-01-20 for my G80.. Found a site with a 'spring sale' right now listing them for $149. $220 shipped to me in AZ.
https://www.mlperformanceusa.com/search?q=E10-20-049 Also on sale is the all corner G80/E10-20-049-06-22 and G82/E10-20-049-01-22. Seems like a steal currently. |
M4Lou462.50 |
