02-16-2023, 07:42 AM | #23 | |
Rep 690
BMWRacer5232522.00 |
02-16-2023, 09:21 AM | #24 | |
Rep 1,396
Sounds like a defective battery or voltage sensor. How did you plug in the battery? Should be positive on battery and ground on the other side I believe. Worked for me. |
02-16-2023, 10:00 AM | #25 |
Rep 255
Update:
Boosted the car. Started no problem. Drive for 45min to the dealer who checked out the car. It was the UVP that tripped. No other issues were noted at this time. Now that its voltage is back up, the battery tender recognizes the battery now and is currently charging it up to full capacity. So far so good…fingers crossed |
14
jpdchicago1365.00 jmg18872.00 02M3ForMe4278.00 bri10426124.00 Mcc420476.50 M3LISSA809.50 Mar481100.50 DocWeatherington2948.00 smaglik529.00 M3ANSPEC393.00 Mamba283.50 Limegrntaln13701.00 DSTR1284.50 Jimjamz4603.50 |
02-16-2023, 10:57 AM | #26 |
Rep 255
DocWeatherington2948.00 |
02-16-2023, 11:04 AM | #27 | |
Rep 255
I took it out for a nice long drive (weather has been unseasonably warm in Toronto) with a few restarts along the way and no issues. Right now, it’s back in the garage and charging (currently at step 3 of 8 charging steps) |
02-16-2023, 11:57 AM | #28 | |
Rep 1,396
Good luck and enjoy the car! |
02-16-2023, 12:37 PM | #29 | |
Rep 328
2023 M4 Comp
Dravit Grey Metallic Last edited by Anderson11; 02-16-2023 at 01:06 PM.. |
02-16-2023, 03:57 PM | #30 | |
Rep 255
So far, battery is on the 6th of 8 charging steps. So far so good. |
02-16-2023, 10:20 PM | #31 | |
Rep 608
You should be directly on the battery in the trunk.
G80 Comp, Hcp custom e50, 9.69@141
F90 Comp, Hcp custom e40 meth, 9.76@143, 174ml/h 1/2ml 60-130 5.53 F10 M5, HCP Tune ,BM3, 10:8@137, 166.05 1/2ml. Ig @mcc420 |
Needsdecaf6940.50 |
02-17-2023, 03:53 AM | #32 |
Rep 255
You would think…. But according to page 336 of the owners manual….
Charging the battery Charge the battery only when the engine is off and via the jump-start terminals in the engine compartment. Additional information: Jump-start terminals, refer to page 340. Besides, the battery is in the trunk and is relatively inaccessible. Final Update: Battery is now fully charged and all is good in the world again! Last edited by Znomorph4theWin; 02-17-2023 at 04:03 AM.. |
02-17-2023, 04:54 AM | #33 |
Save the Manuals
1718
Rep 2,940
To all you CTEK battery tender guys, get an ANCEL Bluetooth battery monitor or CTEK battery monitor, hook it inline with your cables and take the guesswork out of your tender charging status.
I use both for multiple vehicles. Handy esp. in winter
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT |
02-17-2023, 12:48 PM | #35 | |
Rep 1,359
SOLD - 2021 M340i RWD
Beever Teef - 2022 M440i GranCoupe xDrive |
02-27-2023, 02:39 AM | #37 |
Save the Manuals
1718
Rep 2,940
Yep Lithium car batteries need love too.
The CTEK has a very gentle/gradual charging cycle\process. It ramps up the voltage very slowly. After it reads full/ green I let it float for a day. But I don’t leave it on. After a charge up cycle is complete in 24-48 hours I disconnect it. I only charge it when needed. (No potential sulfation issues like a SLA/ AGM).
2023 G80 6MT, CCBs
02-27-2023, 05:42 AM | #38 | |
Rep 255
02-27-2023, 01:38 PM | #39 |
Rep 360
Mine has been on a CTEK charger since August (I haven't been home since them). Just in the last 2-3 weeks the bmw app no longer has any info on the car, so, it looks like I might have this in my future. Thanks for posting this up here, OP.
2007 X3
2022 M3 Base |
Limegrntaln13701.00 |
02-27-2023, 02:38 PM | #40 | |
Rep 255
Regarding the app. Besides a dead battery…consider this…. My car is stored in my garage. I’ve noticed occasionally that it might not connect to the mobile network because it’s not in an open environment. This will not allow to the car to connect to BMW servers so the app won’t update. As soon as I open the garage door and move the car outside , it quickly connects to the network no problem and the app works perfectly. In other words Signal strength might be a cause as well… |
smaglik529.00 |
02-27-2023, 03:01 PM | #41 | |
Rep 360
2007 X3
2022 M3 Base |
02-27-2023, 03:12 PM | #42 |
Rep 255
02-27-2023, 09:52 PM | #43 |
Save the Manuals
1718
Rep 2,940
Occasionally I’ll toot the horn to test the connection.
I’ve also found the tire sensors are not spot on in the app. I measure to 0.1 lbs with my digital gauge and the tire pressures are exact. The sensors read 3-4 lbs high
2023 G80 6MT, CCBs
02-27-2023, 10:10 PM | #44 | |
Rep 421
Had to have it dragged onto a flatbed on the way to the dealer. |
