01-05-2022, 04:17 PM | #23 | |||||
Rep 2,350
I did not disconnect the 48V battery before charging the 12V trunk battery. There was no literature and indications about that. Actually, the manual lacks any kind of information about that. I did however disconnected and insulated the ground on the 12V battery before charging it. After the battery was charged, I reconnect the trunk battery. Quote:
Why BMW did not explained this and provide some instructions ? Quote:
A video might help, however, we can not post videos in here… And I am confused; shouldn’t the hood be OPEN when charger is on? I believe that the manual says so. Quote:
The question is, how long you will keep a vehicle at 3-4000 rpm? Is this a fast charge thing? I will look into it and get back with my results. Thank you again for your help! I really really appreciate it! |
barcelona271.00 |
01-12-2022, 11:57 PM | #24 |
Rep 3,456
Drives: Harrop E90 M3
Sorry for the late reply, been busy. I almost created and posted a YouTube link for this but here's a few pics to show the process of disconnecting the 48v battery to charge your 12v in storage.
The battery charging in idrive is found under driving info, power flow to charge your 48v battery. I hope this helps. Let me know if you're successful and what the specs are again on your 12v charger. Edit: mobile uploads jumbled the order of the pictures. 🤦🏻*♂️ hopefully you get the idea/process. 3,1,2.4.5 for disconnecting the 48v system. |
01-22-2022, 04:23 AM | #25 | |
Rep 2,350
I charged the big trunk battery via trunk after disconnecting it, using the NOCO 5 charger. I will however report back if your suggestion will work as soon as I will try it. Thank you again for everything! |
02-02-2022, 01:58 AM | #26 | |
Rep 2
MilehighM3 , could you please elaborate on the 30A charger? Where is it documented? And also if you can recommend any chargers on the market that can do that? Most of chargers, at least on Amazon are "smart" chargers that do not produce nearly as much.
I attempted to charge my car with CTEK 7002 , and I measured a bit over 6 AMP on the wire. Though after many hours chargers finished the cycle, but I heard that motor activation sound every few minutes as many describe here. Quote:
06-14-2022, 05:51 PM | #27 | |
Rep 2,350
06-14-2022, 05:52 PM | #28 | |
Rep 2,350
09-13-2022, 06:28 PM | #29 | |
Rep 5
The common theme in most of the threads is that the behavior doesn't seem to occur with 25A or higher chargers like those used in mechanic shops or showroom floors, so I went ahead and purchased a CTEK PRO25S battery maintainer to hopefully confirm a solution. I connected the PRO25S, hood open, car locked. It charged to full and went to float in about an hour. No noises or activation sounds from the car. My only concern is although the website specs state AGM compatible, there is no specific AGM mode like the MXS series had. I sent an inquiry to CTEK to see if they can provide some clarification. So far so good though. I will update if there are any issues with the car or battery life. The professional charger is pricey compared to a regular consumer models, but simpler than any of the workarounds I have read about so far. |
tracer bullet2545.00 |
09-14-2022, 06:48 AM | #31 |
Rep 2,350
10-09-2022, 10:14 AM | #32 | |
Rep 389
My guess is that the MHEV system in these cars does something funny for a while after connecting a charger while consuming a high current. I haven't measured the current to the 12V battery but the voltage at the charging posts stays normal so my conclusion is that the current to the battery is not too high. As can be seen in my voltage/current plot the current rise to 17.5A at the beginning but then reduces while the voltage increase to a normal charging voltage of 14.1V. A car charger which is specified to be used on a battery while still being connected to the car should be safe to use even with a high current rating because it will make sure that the voltage doesn't exceed 15V or so. No cycling of click noises was heard. |
10-09-2022, 01:05 PM | #33 | |
Rep 2,350
The problem is that the clicking is present in some models and that is worrysome. I will not leave that charger in there and have that grinding and clicking noise non stop as I don’t believe is ok; ai contraire. (In regards with your CTEK CS FREE, is intended for Lead acid /Lithium-ion so not sure how that works on the trunk AGM battery). Either way, 20 A still seems aggressive for the battery charging requirements. The 5 max 10 are suggested for the battery as they are more lenient. Probably if you use the regular 5 or 10 Noco, you will experience the same problem? As mentioned before only my M340 does that. So the problem is still pending… |
10-09-2022, 01:48 PM | #34 |
Rep 389
This is just a guess, but a stronger charger might allow the car to get pass what ever it does while requiring the high current to get it to shut down and let the charger charge the battery. Notice the sudden change in both current and voltage at about 1 minute in my plot. After that the charger keeps the voltage at 14.1V and the current gradually decreases as expected (the battery was not discharged). The voltage when the current was high was not remarkably high so I beleave that the current was consumed by something else than the 12V battery. And yes CTEK specifies it for "12 V: WET, MF, Ca/Ca, AGM, EFB, GEL, LiFePO). The same for CTEK PRO25S which I assume should work for you.
10-09-2022, 02:51 PM | #35 | |
Rep 2,350
Based on previous replies I also have the same presumtion in regards with bigger amps pushing through. I probably need to buy a bigger charger, yet, again my X4 which is also MH takes the 5 or 10 Noco with no issues. I am more interested in why does that and why BMW did not come up with an explanation as the chargers they are selling through BMW part Dpt are maximum 5 Amps, and obviously do not work. I still want an official answer and charging steps. |
10-09-2022, 11:03 PM | #36 |
Rep 389
Oh, so the X4 can now be charged with a 5A charger?
Earlier you wrote: "I have a Noco 5 I think. What are you using? I don’t get it. Both M340i and the X4 have the same clicking noise and no charging." What, do you think, is the difference, did the X4 get a firmware update? Is there a difference in how much charge there is in the 48V battery when you charge now compared to earlier? |
10-10-2022, 01:29 AM | #37 | |
Darth ZEDer
6304
Rep 1,143
Drives: 2022 BMW Z4 sDrive3.0
First of all, I'm a BMW newby, took delivery of my very first BMW at the end of August, a '22 Z4 30i (B46TU engine). Recently, I was surprised to discover my Z4 has a second battery (and it's only used in the 30i Z4 variant, not M40, though also used in many other BMW models). In addition to the 80a AGM in the trunk, it has an LG Li-Ion 10Ah, 132Wh, 13.2v battery that looks similar to your battery and is located in a similar location in the engine compartment. It's been challenging to find info on this but apparently BMW calls it a dual storage system, suggesting it may be significantly different than your mild hybrid system. FWIW, both my NOCO 5 and NOCO 10 work as expected. I ran across the following document in a separate forum describing the dual storage system which I believe came from https://bmwtechinfo.bmwgroup.com: ST1856 General Vehicle Electronics 2018.pdf Perhaps you can find something on your MHT at that site though sadly there is a fee to access it. |
10-10-2022, 01:30 AM | #38 |
Darth ZEDer
6304
Rep 1,143
This is of no help to your request for an official answer and charging steps but just a reference point to how another model relates (or not).
First of all, I'm a BMW newby, took delivery of my very first BMW at the end of August, a '22 Z4 30i (B46TU engine). Recently, I was surprised to discover my Z4 has a second battery (and it's only used in the 30i Z4 variant, not M40, though also used in many other BMW models). In addition to the 80a AGM in the trunk, it has an LG Li-Ion 10Ah, 132Wh, 13.2v battery that looks similar to your battery and is located in a similar location in the engine compartment. It's been challenging to find info on this but apparently BMW calls it a dual storage system, suggesting it may be significantly different than your mild hybrid system. FWIW, both my NOCO 5 and NOCO 10 work as expected. I ran across the following document in a separate forum describing the dual storage system which I believe came from https://bmwtechinfo.bmwgroup.com: Attachment 3004079 Perhaps you can find something on your MHT at that site though sadly there is a fee to access it. |
10-10-2022, 08:46 AM | #39 | |
Rep 2,386
Drives: Z4 M40i
https://static.nhtsa.gov/odi/tsbs/20...12793-9999.pdf |
barcelona271.00 |
10-10-2022, 11:22 AM | #40 | |
Rep 2,350
The M340i gives me headaches as it is different. |
10-10-2022, 12:08 PM | #41 | |
Rep 2,350
But no, is not responsive. We are talking about charging the 12 V AGM (main) trunk battery, not about the small 48 V engine compartment one; that one charges pretty fast when vehicle runs. No, this does not address the charging issue that we encounter when we are trying to use a charger via under the hood connection (as per manual), which consist in a electric motor noise followed by a click in the 48V battery area -> which resets the charger to start again from zero. Even with the 48 V battery disconnected, the behaviour is the same. Either way, even your instructions show how overly complicated everything is for not much gain… And BMW still didn’t come up with a proper procedure. My mechanic treid two other new vehicles form the dealer lot and they all behave the same with three different chargers; except his shop professional one which is huge and no regular guy owns… If you can find the answer to the 12V battery charging procedure (beside the book that doesn’t help), I will be interested. Thank you again! |
10-10-2022, 03:38 PM | #42 | |
Rep 129
So this is interesting are you revving the engine in sport mode while driving or in neutral? |
10-10-2022, 08:03 PM | #43 | ||
Rep 3,456
10-20-2022, 09:17 PM | #44 |
Rep 1
BMW trickle charging problems
I purchased my 2021 M440i with a BMW provided trickle charger. After having the charger on for 4 months it remained hot (hood open) even though it eventually got to the last charging level. It made the car whine. Worse of all it twice knocked out my Sirius radio requiring a computer replacement (the first time I thought it was a fluke. Has anyone heard of BMW addressing this problem?
