09-05-2021, 08:28 AM | #23 |
Rep 280
I'm impressed with the 1/4 miles numbers. The best I ever did on my stock F82 was 11.7; with the hp improvements I'm seeing relative to a midpipe and intake I will look forward to seeing those numbers.
09-08-2021, 08:04 PM | #24 |
Rep 636
Drives: f32 430ix & 982 GT4 PDK
You are in the 10s with this car on pump gas with a tune. Pretty big step up and S58 delivers.
09-08-2021, 10:02 PM | #26 |
Rep 494
This is a pump gas thread chief i ran way faster with like 2 gal of E and hotter maps. E85 tune will run 9s. No question in my mind
09-09-2021, 07:27 AM | #27 |
Rep 494
Ok so i added the PSI mid pipe yesterday. Jb4 on map 6 dialed boost back to 25 target because i wanted the car to adapt and im running 93 octane. The mid pipes definitely make power im running as fast as i did on E20 with 26 psi of boost. Well done lads at PSI. This may be the first documented 60-130 in the 7s on pump gas.
So Jb4 map 6 93 octane Bmc cone filters PSI mid pipe G80 awd
09-09-2021, 01:28 PM | #28 |
Rep 32
Dialing in mid range boost map 6 with a couple tenths improvement 60-130 G82 MT peak boost 22psi 6-7k rpm
Slight bump in 3rd gear set the TC to kick in a bit and you can tell the 60-70 60-80 suffered quite a bit so there's maybe even more in it! |
09-09-2021, 02:55 PM | #29 | |
Rep 494
Also, just do a pull starting in 3rd gear it might be faster
GabbyChaves60.50 |
09-09-2021, 07:37 PM | #30 | |
Rep 636
PLife647.50 |
09-10-2021, 08:33 AM | #33 |
Rep 494
Ok this is with the PSI midpipe installed. 93 octane jb4 map6
This has got to be some sort of record for pump gas
Avaley736.00 Steveo153.00 babyghost94.50 Patton2502939.50 TrentMeister2953.00 02M3ForMe4278.00 jpichardo91161.50 |
09-17-2021, 08:38 AM | #36 |
Rep 475
Really great that you hit mid 10’s at 130 on pump/tune/mid pipe/intake. This car is definitely impressing me and living up to expectations! Thanks for putting this together.
Sold 2018 F80 M3
Sold 2010 Nissan GTR Sold: 2008 335i |
PLife647.50 |
09-17-2021, 08:41 AM | #37 |
Rep 494
Thanks Boss. Yeah its bananas. I am trying to hit 10.4 with e35 on the same 25 psi target map 6. Just need to dial back the extra power at launch with ethanol so it can hook then it pulls to the moon
10-15-2021, 07:30 PM | #38 |
Rep 33
very first try right out of break-in service, g80 awd petro94
come on guys throw your numbers, we need to fill up these leaderboards adding some goodies tomorrow new times to come !!! |
10-16-2021, 08:19 AM | #40 |
Rep 6,595
Car type: 2022 M3x
Fuel type: 91 (75% full) Tune information: Bone stock Exhaust/intake modifications: none Rims / tire sizes and brand: 826M with P0's Road surface if applicable: asphalt Launch technique if different from owners manual: LC as described in the manual Last edited by forza1976; 10-16-2021 at 09:05 AM.. Reason: updated car details |
10-16-2021, 09:31 AM | #41 |
Rep 2,538
10-17-2021, 11:49 AM | #42 |
Rep 494
thread updated with times in leaderboard. map6 is where you input the tune parameters yourself.
